Pwll Dylluan Railway - Welsh NG in the mountains
Thanks Mel -had fun smashin them too :)
Hercules letting off steam under the bridge
the whistle is mounted under the tender, and gives a good cloud as well as sound
Russell with a W&L style timber train
would look better with logs though, and chains between the bolsters [plans.....]
Some more great pictures, Paul, looking really good.
=Wish I had some of those rocks - all we've got locally is crumbly chalk:wits:
thanks Keith
the rocks - from various building / digging works, also a lot are just lying around in the fields
thanks Keith
Hi Paul (hope you've forgiven me for my offer to swap my sparrowhawk(s) for your mole(s) :bigsmile: ) looks as if you've solved the problem pretty well, really looking good.....
must admit to having run out of my own supply of rock - will have to dig a few more gardening areas for my wife, sure to find a few more :rolleyes:
Regards
Rob
robsmorgan said:
thanks Keith
Regards
Rob
I'd swap anything for the moles - mind you they seem to have calmed down a bit since I've banged a lot of slates into the ground
the sheep is getting back in again now :(
good luck with the rocks
Stainzmeister said:
Just caught up with your thread Paul.....the new section looks great (I knew it would)
Hi Paul
cheers - loads to do yet
hope you're doing ok
I thought it was time to spruce up my timber train as per W&L in Cartwright's excellent book
I cut logs to the longest I thought I could get away with
attached to the bolsters with rubber bands - temp arrangement til I can sort something out with chains
The bolsters worked well and looked good snaking up through the bends
photo by my son
his are better than mine usually
mind you - he can get down lower
Cheers Mel
looking forward to seeing that laundry in its new location too
haven't posted for a while - everything seems to get in the way of railway activity
a bit more work on the landscaping though, a ton of slate chips, and some more stone on the quarry mountain
Russell and train bunker first, ascending the spiral
from the other direction, with a log train
plans are afoot for a disused 32mm quarry feeder formation across the slate
once the slate and membrane has weighed down and killed off the grass for a while, a roadway and yard can be laid
