Corroded through contacts, perhaps?
Is there not a link you have to fit on the LGB model, in order to program it? - It has not been mentioned, and I might have dreamed it??
Have you only got the one? - Could you compare with a different one, to prove you are doing things correctly?
Would you please define "link".
Thanks.
Not in this case, Dan, the only CVs are 1, 2, 7, 8, 9 and 60, and a reset is done with 8 to CV8.LGB had a different standard on many products, write a 55 to CV 55.
Thanks.
I c
an "read" the following addresses from the decoder (which is attached to a switch machine).
CV 1=77
CV 2 =0
CV 7=18
CV 8 = 131
CV 9 = 0
CV 60 = 16
The device will not allow reprogramming. I get a recurring message when attempting to "write": "Programming error".
