Ralphmp
I recently invested in the Massoth PC Module as I am planning to install / upgrade more appropriate sound files in my locos which use Massoth decoders.
My first attempt has been to try and put down the Stainz soundfile onto a new eMOTION S decoder and after several hours I'm stumped.
I have loaded the DCC Programmer software (I used the latest version downloaded from the Massoth web site, not the version on the CD that came with the PC Module) and this recognises the PC Module OK; it tells me that it's version 3.1. I've then tried connecting the S decoder both via the high-speed update (SUSI) and programming track connections (it's not in a loco at present) but every time I try and read either all the CVs or a single CV I just get "Error: Read Error" messages.
The manual with the decoder tells me if I have a 2013 board I don't need to plug a loudspeaker into it as a programming "load" - the board has a flashing LED. However, as I can't see any LEDs I'm assuming I have a "pre-LED" decoder. So I hooked up a speaker and when I try and read CVs I get some noise out of the speaker which coincides with each attempt to read data from the decoder. I'm therefore assuming I have connectivity between PC Module, decoder, and PC.
I saw that PhilP recently had some issues with programming S decoder soundfiles but he could read / write CVs so I'm guessing I have a more fundamental problem.
Any suggestions, hints, tips, etc. would me most welcome.
Thanks
Thanks
