Reower to the points
minimans said:
You must feed the LGB switch box with AC current no if's or butt's! I use a 24V 5amp AC power supply for mine. the switch motors themselves are DC. Supplied rectified DC by the switch box with internal diodes.
[/Drift]
well done, paul - back on topic.
I use an 18vac 0.5 amp to a box that works the same way as the LGB one.
Voltage drives distance, not current, so more amps won't compensate for greater distance to the point. What more amps will do is fire more than one motor at once. 16v ought to work over a reasonable distance, and clearly it does - intermittently.
Here's my suggestions of what to check before spending money :
Does the point move freely ?
Does the point 'click'over when you put it across ?
Shift any crud around the tiebar and motor including stuff trapped in the tiebar
Lubricate the point and motor - I use wd40 but its up to you
Does the point go fully over when you push it ?
Sometimes you can displace the little rack inside the motor by one tooth - check it.
Is the motor level and flat ?
Are the wires corroded ?
Again wd40 may help
Are there any duff joints in the wiring ?
New one this one - I twisted the wires together and forgot to solder it :Looser:
Are there any kinks or shears in the wiring ?
Check as much as you can see, you'll be amazed what happens.
Are the connections to the switch box sound ?
Is anything else sharing the 16VAC power supply ?
Finally, try a different AC power supply - maybe the accessory output of an LGB controller - in case the H&M unit is a bit weary.
If you've built the LGB equivalent of Waterloo station, then ignore the above an buy a 5 amp power supply....
Best of luck
