JimmyB
Having modeled in other gauges, most points are self isolating, in effect power to each branch from the point is made automatically according to how the point is switched, this meaning that sidings etc. do not require additional isolation. Beginners in G are not always aware that power is continuous to both branches at all times when they start, but soon adapt to this methodology. However I have thinking (maybe not a good idea) but if the connections under the point were removed "as required" then the point would not need the track isolation and power could be fed via a switch, not quite the same as other gauges, but would this work?
