These roofs are a nightmare, on the bright side yours doesn't have marker lights, chances are the wires feeding them would be damaged. Don't ask me how I know!!
As you can see in the pics the roof seperates below the marker board and the small wedges are used in my ho diesels to aid body seperation. I bought the wedges off e-bay but you can inprovise.
Even though the seperation is below the marker board you need to start above the board above the O and U with a thin blade driver to allow the insertion of a wedge, then work towards the cupola inserting more wedges. The cupola seating is fixed to the main body of the caboose. You should by now be able to work the roof loose on the side you have been working and you can insert the door into place, with both doors at the rear of the caboose insert a piece of flexible plastic or foam between the doors to keep them in place and snap the roof back on.
Thinking about it you could try wedges behind the marker board pushed up from the caboose side.
Don't forget to take the roof a cess ladders off at each end!!
Just add that I used a drovers caboose instead of a combine because my G stuff is all packed away at the moment and this was easy to get at, same principle on the roof.
