Hello all.
I come pleading looking for help to stop me going nuts.
The background:
I have 2 PIKO BR 80 motor blocks, which I am going to use for COCO diesel bogies. When you buy these they come with no instructions and nothing to attach the pins for electrics. Having recently done my LGB LCE train I kinda figured I'd need wire between some of these pins. Not having a clue which with a bit of trial and error I got there. on the photo below where I have put the black lines indicates which should be joined. This is S1 to M1 and, S2 to M2. Simples.
So after testing, both motors ran. I then built a frame for the side frames and started to think about LEDs for the front of the loco.
I thought it would have been a case of just cut one of those wires and add appropriate resistors and led facing the correct direction. Well firstly I tried 2 LED in series tested in both fwd and reverse and nothing happened, no power to wheels, or to LED. I tried making a simple set up with 1 resistor and 1 LED, This gave me light, the LED lit BUT the wheels would not turn! I attempted the single LED in various other configurations and got nothing at all.
The LED I'm trying to use are 3 - 3.6V warm white 5mm and the resistors came with them for 12V power source.
If any one knows how to get lights and wheels moving I'd be very appreciative.
The background:
