Having read some great reviews of the Piko BR218 particularly regarding reliability and having decided that my wallet does not stretch to a new Countess, I jumped at the chance to acquire a second hand 218 in Maroon. I have added red LEDs for the rear lights and some little GOW bulbs in the cabs for some cab illumination. All of this is wired to a Massoth XL decoder. This is by far the largest and heaviest engine I own, the others are an LGB Track cleaner with MTS chip (I guess), a Baguely with an ESU LokPilot XL (lots of additional weight and skates - now an excellent runner), a GRS 0-4-2 on an LGB Toytrain chassis with a tiny CT Elektronic DCX51 decoder and a Scratchbuilt GW railcar on two USA trains power bogies with a Massoth XL decoder and power buffer.
Initial results with the 218 were very promising all the lights work well, no flickering at all as the loco goes round so presumably there's good pickup, however the loco variously stutters and jerks during running. I put this down initially to needing to set up the Back-EMF correctly, however I've now tried pretty much ever combination of back-EMF settings I can think of including turning it off, but I still get stuttering at some speed. I have tried taking the power buffer from my railcar and putting this into the 218 which certainly helped a little, but has not cured the problem, it now sometimes slow right down to a stop, pauses (maybe while the capacitor is recharging?) and then speeds up again. Interestingly the Railcar has similar problems when run without the power buffer, but runs perfectly with it. My railway is pretty modest in sizing as it squeezes into a London garden, however I am aware that there are some voltage variations along the line as I have current detection sections for computer controlled automation (which is how it runs most of the time) which are independently fed from the shed (probably on slightly under size cable) and I wonder if this may be the problem. The main reason I'm not sure is that my other four locos would often run for up to eight hours without a hint of a problem and with lesser quality decoders. I suppose what's different about this loco is it's weight (my railcar which also has two motor blocks is very light - probably too light, but since it doesn't pull anything and has the two motors it has no problems with traction), it is much heavier than anything else I own. I can't directly measure the current pulled on the track, but I can measure the current to my Lenz command centre. The track voltage is nominally 18v and the supply voltage is to the command centre is 21v DC. The 218 draws around 1A from the supply (so I guess a tiny bit more on the track) which is about the same as my Baguley draws.
So I am a bit stumped as to why I am experiencing these problems, my next action is to take the ESU decoder out of the Baguley and try it in the 218 instead. I am wondering if the Massoth decoders perhaps don't deal with the voltage drops well, although I'd have thought the cheapo CT Elektronic HO decoder would be the one to show problems. The ESU lokpilot does have a small power buffer built in to it and in the Baguley has been faultless so I'll give that a go in the 218 next. However if anyone does have any bright ideas or suggestions I'd be very grateful to hear them! I hope I've explained it all properly...
Cheers
Cheers
