As some of you will be aware, my trailer based layout operates on batteries feeding the track (via a simple speed control).
I use a 3amp automotive blade fuse for protection and sometimes I go through fuses like shelling peas! Is there an auto reset breaker I could try in place of the fuse? I've tried searching but the only type that I can find is for AC up to 230v.
Fuses are cheap enough in bulk - its just a nuisance sometimes. I know what the main problems are in causing the overload/shorts (too many trains in operation, sharp curves and points coupled with errant pony trucks on the Bachmann locos - tried weights).
Anybody any thoughts?
