Granitechops
Narrow Gauge 1/12th scale on 45mm</br>Quarrying &
Re: Options for avoiding a sharp corner, Also on a severe gradient ( Hind sight is wonderful)
Just one comment on yesterdays ballasting
I tried a slightly different method on this stretch of track
The track is screwed down to battens in the sub base to hold the corners,
& 4-5 ft straights left not screwed,
The track was then part ballasted with dry cement - sand mix
This is strong enough to hold the track alignment between screw points.
IF there is a lot of expansion in the summer sun,
it should be weak enough for the whole lot to float sideways YET still hold its basic shape
It will then be ballasted with the proper 2mm grit seived out of some concrete ballast
fixed with pva
The reason for the two part ballasting?
I dont trust the pva alone to hold 100% grit ballast, as it is suppose to soften when it gets wet
AND
when its dry, it probably would have too strong a grip to allow bodily movement of shaped track formation
You may also notice that while the cement mix is setting off I have held it off the cliff face for clearance with bits of wood spacers
fixed with pva
AND
