Fed up running a set of empty open waggons I decided loads were needed. Where to start??? Something light, something reasonably resiliant, something easy to work.
Open waggons often carried coal and other loose products and I'd thought of filling it with small coal. That left a problem with portability. Too easily spilled, and not particularly light anyway.
Clearing up after a different job I moved a sheet of Kingspan (other makes are available), and realised that it was very light, and very easy to cut. I cut a small piece with a sharp knife to fit the waggon.
The foil backing peels off very easily.
Find the right depth
Carve the shape with the knife and rough the surface by scraping with edge of the blade.
Rub over it with your fingers till the required texture is achieved.
Drop the load in and it looks like sand.
No doubt other materials could be stuck to it, that I will try.
The whole thing took only about 15 mins from 'go' to 'woh' for two.
