...signal box
I rescued these sheets from a skip that was outside a school which was closing down:
I found out that I could peel off the shiny coating:
And was left with a sheet of soft plastic type stuff which was very easy to cut. I tested various ways to glue it together. They all worked! The PVA was slowest to dry while Plastic Weld was almost instantaneous, so I went for the Poly cement which seemed to strike the best balance.
After a bit of work with my steel rule and craft knife, it's started to take shape already. It's also very easy to scribe panel lines to represent the planking:
The windows are spare ones left over from my Jackson 'Small station' build and the roof slates will also come from the same source. So this is going to be a 'no cost build'.
I don't think this plastic is weather proof (but perhaps someone with more experience might say different??) so it'll have to be a 'take outside when needed'.
I'll keep you posted with progress...
