Hi guys thinking of trying to controll the layout on automatic.
Reed switches are ( I have found ) are a bit suspect in reliability .
So I am thinking about using NPN sensors fed into my Massoth feed back module. No moving parts water proof and reliable. With the number of loco that I have and magnets for each at £3.00 not a cheap option, now all I would need is a steel strip instead. I thought about which type to use and steel seem to answer the problem. 8mm sensing distance and a 5-36 volt dc supply. Cost here upwards of £30.00 EACH .OUCH.
good old fleabay to the rescue three of them for just under £12.00 brand new from HK. So your thoughts please
