Gentlemen, I did not mean my thread to cause any controversy. I asked because I might solder wires to fish-plates to aid electrical continuity. It was something It used to do with my O gauge track.
The clamps certainly seem to be the best option. Although for the moment I'll have to use fish-plates.
What wattage soldering iron would one imagine would be needed to solder to code 332 rail please?
Thanks,
Sarah Winfield
Track bonding is certainly the way to go Sarah, much cheepervthan Track Clamps. However please use Black Wire! Or the other thing that I have done (in the past) is to use Copper Wire from multi strand Mains, just 1 thread is ample, then allow it to weather and dissapear.Gentlemen, I did not mean my thread to cause any controversy. I asked because I might solder wires to fish-plates to aid electrical continuity. It was something It used to do with my O gauge track.
Thanks,
Sarah Winfield
I recently tried to solder an LGB joiner to a piece of 332 rail using a 100-watt iron and plenty of liquid flux - zilch...
Another little tip try any soldering to the Webb rather than the Top or Middle of the Rail, a little less Metal to heat up. At least 75watt Iron or bigger is the best bet.Don't know watt whatage the soldering iron I inherited from my dad is, but it is a damned big one, best held by the plastic handle, not the pointy end.
Key to soldering LGB: very clean rail and whatever you are soldering it to. Plenty of heat. Flux and Tin each surface first. Hold wire, or whatever, in place (with pliers, you idiot) until solder sets.
...and do it in a sheltered spot, a tad of a breeze, and you lose lots of heat.
Also the sketch from Airplane involving Roger, Victor and Clarence.
Sarah Winfield
It's a good job we humans can laugh at ourselves.
It probably spends more time laughing at us.
MMmmm, very interesting but.......Though I'm using some Aristo track, including a wide sweep of their very large curves, I'm not going to rely on the little screws - for the sake of the extra few quid it will cost, I'll be ditching the Aristo screwed fishplates and using Massoth clamps on everything.....
I've relied on those little screws for quite a few years now, without too many complaints![]()
