curtis
From what I can tell, there is only a single decoder (in the tender). The tender will run without the body. The body won't respond to any function without the tender so I'm not sure editing the max/min speed CVs will help? I'm assuming the suggestion was to calibrate the tender and the body separately in the event they had a decoder each?
Pickup continuity seems fine but Phil's suggested triggered a thought. I identified the motor cables and tested with direct DC from an LGB start set and found the body itself isn't running smoothly - there is a certain jerkiness and low voltage gets no movement (although I can hear the motor trying). To get the wheels to turn at a medium speed ends up drawing just under 1A which feels too high given my experience with LGB locos. I opened up the motor block to have a look can can't see anything odd other that what looks like fine plastic filings around the middle wheel set. I gently lifted the wheels and ran the motor without load and seems to spin freely.
I reassembled but still seem to be in the same situation (not withstanding anything I may have done to make it worse...)
