duncan1_9_8_4
Garden Railway Operator
Fantastic pictures, never knew such things existed!
marshman said:Gave the Shay a trial run today on some test track along the path.It is fitted with phoenix sound & is also rigged up to run on battery power from a trailing truck. Have been a few teething problems. Ran fine in reverse to start with but then cut out when going forward. After awhile ran in both directions but then cut out again. Seems to be a short as lamp does not power up. Tried another loco that arrived this week, a little Davenport & it ran fine in both directions so don't think it is track. May be it draws to much power?
Anyway when it was running it was great.![]()
pugwash said:You're excited aren't you? We can tell by the camera shakemarshman said:Gave the Shay a trial run today on some test track along the path.It is fitted with phoenix sound & is also rigged up to run on battery power from a trailing truck. Have been a few teething problems. Ran fine in reverse to start with but then cut out when going forward. After awhile ran in both directions but then cut out again. Seems to be a short as lamp does not power up. Tried another loco that arrived this week, a little Davenport & it ran fine in both directions so don't think it is track. May be it draws to much power?![]()
Nifty little loco, would send me all of a shudder too![]()
marshman said:pugwash said:You're excited aren't you? We can tell by the camera shakemarshman said:Gave the Shay a trial run today on some test track along the path.It is fitted with phoenix sound & is also rigged up to run on battery power from a trailing truck. Have been a few teething problems. Ran fine in reverse to start with but then cut out when going forward. After awhile ran in both directions but then cut out again. Seems to be a short as lamp does not power up. Tried another loco that arrived this week, a little Davenport & it ran fine in both directions so don't think it is track. May be it draws to much power?![]()
Have taken a few more pics today without my glasses on.
The trials continued today, gave the moving parts a light oil & loco running has improved & it is drawing much less power.
The tribulation also continues, runs superb in reverse but not forward.Get a little flicker on the lamp & then nothing.Did get one blast of sound once in the forward position & then died. Any ideas?
The sound is incredible. The speaker is mounted in the chimney spark arrestor & you can here the loco in the house with the doors & windows shut.![]()
MR SPOCK said:marshman said:pugwash said:You're excited aren't you? We can tell by the camera shakemarshman said:Gave the Shay a trial run today on some test track along the path.It is fitted with phoenix sound & is also rigged up to run on battery power from a trailing truck. Have been a few teething problems. Ran fine in reverse to start with but then cut out when going forward. After awhile ran in both directions but then cut out again. Seems to be a short as lamp does not power up. Tried another loco that arrived this week, a little Davenport & it ran fine in both directions so don't think it is track. May be it draws to much power?![]()
[align=center]Throw yer specs away, picture superb what a sweet looking engine that is like the idea of the speaker in the stack that is neat.
you said this is running with a battery is there track power as well? most things work slightly better one one way than the other but this sounds more to it, especially if the light goes out? I had a loco that had one set of drivers not in line with the rest would run perfect one way and jammed solid the other , check for 90 degree cranks all round,that is on the cylinders, disconnect the drive to the front truck test, same rear set, then both sets, see if the light comes on,with no load on the wheels run it on blocks, sorry if all is egg sucking
[/align]
trammayo said:Nice loco - I can see why you wanted (I'll just have to drool for the time being!). Hope you get the snags ironed out.
Mick
Spule 4 said:Shays are intereting locomotives. Many saw logging and other industrial uses.
There was even a 760mm gauge one sent to the Austrio-Hungarian area, I think it ended its days in Slovenia (Yugoslovia). It was bought/imported by Krauss-Linz and operated on a test basis on the StLB if memory serves.
marshman said:Shawn said:Sweat. I love the shays just wish I could afford one.
Shawn it was your fantastic railroad that inspired me to go the logging/mining road. I hope to build a small layout in my shed this winter, a small end of line depot similar to yours & run the shay on that. With your permission I thought I would call it "Shawnekitty". Funded most of it by selling off most of my Aristocraft stock. Still got a loco & caboose to go which I will use to get some logging disconnects & iron mountain coal cars.
steven large said:WHY called shay for this steam loco and why need a name for shay?
MRail said:steven large said:WHY called shay for this steam loco and why need a name for shay?
Invented by a man called Shay.
Google Ephraim Shay.
