artfull dodger
Picked up an older Accucraft C16 that had seen better days, had what appeared to be timing issues and massive blowby in both cylinders. She has slide valve cylinders and inside Walschearts valve gear. Timing was way off on the engineer(starboard) cylinder. That was an easy fix, I pulled both cylinder heads and took the pistons out, both O rings had perished being rock hard and flat. New O rings were installed and she was reassembled. By 3am she ran on air, nice and smooth in both directions. Off to bed I went. Today I have degreased the chassis, and will proceeded to redo the broken rear boiler mount in the cab and get the engine reassembled. Old 268 might run on steam yet this weekend.
