Hm looks like the carp has filled the boiler. So heeding Jimmies warning, silicone gloves and a good face mask to keep all dust out/off of you you will need to scrape out what dust you can with a small screwdriver. Possibly via an old plastic bowl with water in it, once a good load is out you may be able to tease the weight out. Then a good clean i side IN water with an old toothbrush should sort out the crud. Then time for you, clean cloths and shower in case any lead dust has got onto you with clothes being washed in their own.Wow, thanks everyone!! I got the lower chassis cleaned and lubed and assembled see pic. I think I did ok. The major problem though is in the boiler and it's weight. I don't see how to get it out, and I am afraid if I don't , it will just ruin what I just got cleaned up. I attached a pic of the large weight in boiler. I have the screws out, but by looking at the diagram that people have been kind enough to share, it will not slide out toward the cab and the front, smokebox? seems very attached and no way to remove. It was suggested to soak in vinegar to help remove oxidation from the lead. If I place the whole boiler in a vinegar solution, will that ruin the plastic body and wiring? As always, many thanks for any advice here.
Mike
These locomotives are looking to be a bit of a poisoned chalice!
