I've been relaying trackwork to change some turnout locations that were too difficult to reach.
Maybe someone will be interested in my method of ballasting track.
I use a dry mixture of 6:1; 5mm gravel:cement. It’s mixed dry but it helps if you just slightly wet the gravel before mixing – this help the cement powder adhere to each stone. I also add a bit of black oxide to add colour.
It's then placed along the OUTSIDE of the rails only, not between the rails.
I use a ???? brush to 'tamp' the mixture under the outer part of the sleepers.
Then a 'gentle' spray to just wet the surface, not enough to wash the cement dust off!. I use a soft drink bottle with lots of 1mm holes in the cap.
A couple of hours later I repeat the watering, then 24 hours later give it a good soak with a watering can.
Then I fill between the rails with loose gravel.
or see this video.....
http://www.members.optusnet.com.au/satr/ballast3.wmv < Link To http://www.members.optusn..om.au/satr/ballast3.wmv
The result is a firmly held track, which water can drain through, and I can use my leaf blower without blowing the ballast away.
I've used this for 4 years now and it showed it's worth when I ripped out the old track. I was able to break the ballast off the track. Some of the old ballast can even be reused. The larger pieces become landfill for the next project!
