Gizzy
What sort (and vintage) of card?Hmmm, I'm not getting any volts from the blue Aux connector. Tried to see I'd a Function switched it on, tried all from F1 to F16.
I'm trying to power a Fosworks sound module from the Aux feed. I tried a PP3 battery but still no sound.
I was hoping that the Fosworks card would work, but I might have a faulty one....
It's a MYLOCOSOUND 20 D Light diesel which I was originally going to fit in the Piko 20 dinner track cleaner, but there isn't much room to play with, so I thought I'd fit it in a Schoema Shunter.What sort (and vintage) of card?
You need a dob of volts on a motor connection, as well as (correct polarity) power.
Gizzy have you looked at the fitting of a MLS card to DCC chip, not quite as you say so far as I can see. Hope I am not upsetting M Moonraker by including this extract from the MLS instructions.It's a MYLOCOSOUND 20 D Light diesel which I was originally going to fit in the Piko 20 dinner track cleaner, but there isn't much room to play with, so I thought I'd fit it in a Schoema Shunter.
It has inputs from the motor and battery +&- screw terminals. I thought I could power the card from the Aux feed
Those are the instructions I'm following JD....Gizzy have you looked at the fitting of a MLS card to DCC chip, not quite as you say so far as I can see. Hope I am not upsetting M Moonraker by including this extract from the MLS instructions.
You have to connect the sound card to the output that goes to the motor , there is not a variable output on any decoder, the voltages are all set via an appropriate cv. You have no control over the sound card. to do that you need a sound decoder module.I'm trying to find a 8-24 V dc output on this decoder in my Shoema V14 loco.
I assume it's a LGB 55021 decoder, but would anyone know if there is one before I start checking with my multi-meter.
I don't have any documentation for this decoder....
Thanks Phil,A few 'gotchas' :
The metal 'paddles' (in the screw-terminal connectors) go upwards when you tighten the screws. - Make sure the wire is above the metal part, before tightening.
Faint clicks, is usually too low a supply voltage, but I would test the card standalone first. - Minimum to get sound, is a speaker, 9V battery, then touch between battery positive and either motor connection. You can use the tips of your pliers, tweezers, or bent paperclip for this.
You should hear the motor sound.
The auxiliary socket is (in effect) track power, but this being a later decoder, there may be more to it than that? - Without a full schematic, we are guessing a little.
