More mamod frustration
RMurphy195
So, after a few frustrating things that shouldn't happen, now at last learning how to actually run the brunel MK3.
Finally manged to use the boiler topup valve, but...
After its first use, the loco took much longert to build up pressure! After a bit of experimentation trying to trace a leak, I noticed that if I pt a blob of water into the recess on top of the topup valve - air bubbled through, just like when testing a car tye valve for leaks.
So I took the valve off, checked that I hadn't squirted any debris through it, squirted some water through just to make sure. but still no luck.
Its a strange looking affair - like a hollowed-out plug with a tiny bit of silicon tube blocking the inner exit, works a bit like an old bike Woods valve I guess.
Ideas anyone, short of simply converting the valve into a blanking plug with a dab of solder?
Thanks - Richard.
Thanks - Richard.
Hm sounds like the Safety Valve so do not do that! Sounds as if you may need a new revised one but be sure. I assume you mean the Valve on top of the boiler?
It's not the safety valve, that is on the standard water filler. I have never used thetop-up valve. Try changing it for a standard bolt and O ring and see what happens
It sounds like you have a Goodall valve -the steam pressure forces the silicone tube into the hole, sealing it off. There's not much to go wrong provided the tube is cut to the right length. Might the water be boiling on the top of it?
I think you are right about the water boiling on top of it. Did find some debris on the burner from a match I used to light it with 'cos my gas lighter packed up, so maybe that's the problem!
