Here are three shots of the newly modified Konrad. We must confess to copying some of Rob Bennett's ideas from his 7/8th scale Moth.
They do say that imitation is the highest form of flattery... or something like that.
The first view shows the tender; the long wheelbase is intentional to aid cab first running stability.The tender looks a little small but any bigger, it dwarfed the loco, so this is how it ended up, the flared top helps.
The second shows a close up of the rhs with reversing lever rod, dummy whistle, new dome, old dome as sandbox (cover for topping up valve) and safety valve shroud. The extended running plate can also be seen.
The third view shows the relocated offset boiler (originally it was skewed), the repositioned smokebox saddle (further forward), the new smokebox door, the replacement flywheel and new gear guard and the lift-off cab and spectacle plate. Less obvious is the extension to the frames bringing the new buffer beam about 5/8th of an inch forward.
The design modifications were a committee decision with work carried out at the New Boston Lodge Works (in Boston) by R M Turner
(my brother).
Hope you like it.
Dave Turner.
(my brother).
Hope you like it.
Dave Turner.
