Hello all.
Firstly let me pay tribute to one of our fellow members for making this kit it is superb quality so even I can make it look easy. For more information on this kit please see this thread: http://www.gscalecentral.net/m5148
I believe Rob is considering another run if there is enough interest.
Any way on to the build and how I'm getting on.
As you may have noticed fom the above thread the body is mostly built, as are the bogie sideframes, all we need to supply is the chassis and motorblocks. After some help form other members of the forum the PIKO 0-6-0 tank engine motor block seemed a reasonable fit and was cheap enough to buy two without getting me in any more trouble.
Once the motor blocks arrived I had to figure out a way of mounting the side frames, the side frames are cast white metal and weigh a lot so what ever method I was to use had to be pretty robust. The motor block is a slightly unusal shape and is quite deep, so I decided to make a frame out of brass angle from B&Q to hold the two side frames together which would the rest on the motor block.
Here's a pic to help understand my waffle:
Joints of the frame are held with size 6BA nuts and bolts, and then the white metal sideframs are attcahed to these using selftapping screws, and epoxy adhesive, They are that heavy I wanted to be sure they did not go any where.
The other brass parts that you can see on the white metal such as the brake cylinder are stuck on with epoxy.
