Zerogee
Clencher's Bogleman
I'm having a bit of an odd problem with a new MFX-decoder M/LGB loco, and am hoping that some of you who know your way around the idiosyncrasies of the MFX decoders may be able to help....?
It's a virtually new loco, the most recent MFX release of the stumpy little "Kleine Dicke" Borsig (the one that some people call the "Spremberger"). I bought it brand new a couple of years back, but am thinking about selling it on as part of my ongoing "reorganisation and rationalisation" plans to thin my collection a little.
I've run it a couple of times on my own Massoth DCC system, and have also taken it along to a friend's layout which has a new Marklin CS3 control unit; in both cases it worked fine, all sounds fully accessible (and on the CS3 controller it did the "MFX thing" and popped up automatically on the system as soon as it was put on the track), so I'm pretty sure that all is good with the loco and its decoder. Nothing has been changed or adjusted in the way of decoder CVs on the loco, everything is still set at the as-delivered factory settings (including the loco address at the default "3").
My roller test track has a switch so that I can toggle between DC analogue (LGB 1-amp power pack) and Massoth DCC and back, at the flick of the switch, without having to disturb the loco or take it on and off the track.
So, here's the weird bit: I can run the loco on DCC (Massoth), with the sound working fine; if I then switch my test rollers to analogue DC, the sound continues to work. However once I take the loco off the track and put it back on again, switch the DC power off and then back on, or even just let the loco sit stationary for a few seconds with the DC controller turned to zero, then it seems to "forget" the sound setting and the sound on DC is NOT working after that. Put the test track back to DCC control, and the sound is OFF, but can be switched back on via F6 on the Navigator. Repeat the process, after running with the sound on DCC the loco seems to "remember" to have the sound on when switched to DC, but then forgets it again a few seconds after stopping.
Does anybody here have any experience of this particular problem, or have any idea what is going on? Is it something to do with the heirarchy of protocols within the MFX decoder?
I'm wondering whether switching the MFX protocol off might help, so the decoder isn't looking for that in the first instance... but wanted to ask the question here before I start fiddling with any CVs.
If I was keeping the loco then it wouldn't be a problem because I would be running it on DCC, where it's fine as it is; however I do have someone possibly interested in buying it from me who runs entirely analogue, but naturally wants the running sounds to work on DC (as indeed it should, LGB do state that the sound should function on DC as supplied from the factory).
Awaiting any thoughts with interest, and thanks in advance!
