Fred2179G
Hi Guys,
I have an old Merlin Mayflower converted many years ago to vaguely american, using a wood cab and tender. I got it from an estate years ago.
It is a good runner, as the above photo will attest (Tuckahoe Steam & Gas Show, MD.) However, shortly after the pic was taken I had lunch and then set about preparing it for another run. I filled the lubricator and boiler, then the gas tank. Some time later I went to light the fire as it was almost my track time. I was early, so I turned the gas off after a few minutes so it would stay warm but not waste fuel.
Imagine my surprise when, all on its own, the safety valve lifted 5 minutes later. The gas obviously wasn't off! On investigation, it seemed I could turn it 'off' but there was still a residual flame and it didn't go out. Hmmm . .
This morning I cleaned the loco and took out the gas valve spindle. It seemed old and worn, so I gently polished the point with 400 emery. After putting it back together, I loaded a very small amount of gas and found I could light the fire without turning the gas on. My polishing might have helped but it didn't solve the problem.
Anyone seem this phenomenon before? Any suggestions for things that I can try?
