I see Massoth will be shortly providing add on sound units.... the eMotion S
eMOTION S Sound Decoder
Universally applicable sound decoder for analog and digital operation; equipped with a SUSI interface and a 3 Watt output stage.
eMOTION S The tiny sound decoder.
The eMOTION S sound decoder has the same sound features as the XLS sound decoder.
ANALOG AND DIGITAL OPERATION
ll sound features are available at the lowest voltages possible. A stabilized analog operation is guaranteed at 5Volts.
NMRA DCC and LGB® MTS
The eMOTION S supports the full NMRA protocol. The eMOTION S features an automatic detection of LGB® MTS signals which makes this sound decoder ideal for all generations of the LGB® MTS system. The bus interface may be used with Massoth/LGB® OnBoard or SUSI protocol. Fits into all G-Scale locomotives like Bachmann, USA-Trains, Aristocraft, Accucraft, KISS
AUTHENTIC SOUND in digital quality
The eMOTION S sound decoder produces authentic locomotive sounds in digital high-level quality. Massoth uses only sound recordings of original locomotives adjusted to the sound decoder's technology. The eMOTION S may hold more than 2 minutes of sound. This enormous capacity is sufficient for a variety of additional high-quality sounds. The sound decoder features a 3-Watt high-performance output stage. The volumes of all 16 sounds may be adjusted separately.
Massoth utilizes top-of-the-shelve technology paired with state-of-the-art processing ensuring reprogramming via the programming track. This guarantees that all decoders may be updated at any given time as well as for all new decoder generations to come.
Note: A sound upgrade or firmware update may only be done with our http://www.massoth.com/en/produkte/8175001.en.php < Link To PC-Module (8175001)!
Summary of features:[*]Digital sound module[*]16 kHz sound processing[*]Capacity of sound memory + 2 minutes[*]Analog and digital operation, SUSI interface, LGB® OnBoard[*]Analog operation starting with 5 Volts[*]3 Watts output[*]User-friendly terminals to connect
loudspeaker,
external volume control and
pulse generator[*]Additional terminals for
power buffer
2 function outputs
2 contact inputs[*]Wide range of sounds available[*]Updatable via PC-module
SCOPE OF SUPPLY:
The eMOTION S comes with an attached power cable and the SUSI interface cable.
In case your locomotive does not provide a loudspeaker you may choose one from our wide range of http://www.massoth.com/en/produkte/82410x0.en.php < Link To loudspeakers.[/b]
Measurements: 35 x 20 x 12 mm (plus 2x 5mm extensions which may be cut off)
loudspeaker,
power buffer
2 function outputs
SCOPE OF SUPPLY:
