Loco
I have now installed a Massoth High Performance 19V pulsed smoke unit in the LGB Thusis steam locomotive and are experincing an issue with the synchronicity between the sound chuffs and the steam blows. When I start to run the locomotive it seems random if the sound and steam are in perfect synchronicity or not. When not in synchronicity the sound and steam is off in perfect disharmony, which means: chuff - 1/2 rotation of the wheels - steam - 1/2 rotation of the wheels - chuff - 1/2 rotation of the wheels - steam ......
The chuffs are always correct watching the wheel orientation, it's the steam that can start off at the wrong impulse from the pulse generator.
Connection is as follows:
- Red and black wire connected to F2 on the LGB driving decoder (polarity observed and connected correctly according to Massoth information)
- Pulse signal cable (Taktgeber in German) removed from LGB sound decoder and connected to the smoke unit.
- Pulse signal cable from the smoke unit connected to the LGB sound decoder
CV56=25 (to set 19V on the F2)
- No SUSI connection
I then had 1 steam sound chuff and 2 steam blows for each full rotation of the wheels. That is strange since I should get 2 chuffs for each rotation. So I set CV54=74, which gives load control+load dependent sound+4 chuffs per wheel rotation. But actually I only get 2 chuffs.
Does anyone have an idea what is causing this to happen and why it is random? The smoke unit works perfect apart from this issue.
