D
Deleted member 1986
Guest
Having successfully updated a PIKO 35011 Navigator from version 1.81 to the latest firmware version of 1.92p, courtesy of Massoth.
Whist exploring the menus and features, stumbled over this menu.
Under Navigator Config, down at the bottom of the screen more..., takes you to a option Special Mode, M2 to ok,
under Special Mode are two lines A and B with 1 to 8 .
Special Mode A: A3 needs to be activated, press the number 3.
Special Mode B: My requirements were 1,2,3, and 8
Then press M2 OK, then train to return back to main screen.
Just checked a brand new Massoth 8134501 Navigator, had to set the parameters for the Special Mode, seems by default most of the features require setting up as per the individual user's requirements.
