Yes Roly , currently writing the sequenceof events and how to activate them.
Because you have the Navi here goes
scroll through the menu to auto switch. Here enter the the acton number eg 1 then the sensor number eg 1a
Thrn the point number eg 1 follwed bythe way the point should go. do that for each point so the next would be action 2 and thenas above using the same system. I set the trains in opposing direction which sets the point for the returning train, no need to use a setting
Come out of that then re-enter to auto prog then to auto drive
At this point start entering the action number eg 1 then the sensor number 1a then the loco number 1 then the command 4 ignore the delay confirm on M2
Fed up yet ?
:wits:
Then action 2 with contact 1a the loco number 2 then the command 0
Then action 3 with contact 1b the loco number 2 then the command 4
then action 4 with contact 1b the loco number 1 then the command 0
At this point you then have to activate them do this by going all the way through the above BUT stopat the second line when you activate the system with a right click on the paddle button so you do this 6 times
At the end go back to loco control and begin with the first loco, set your speed and await it returning where it should stop, now change the loco address and set your speed.
And if it doesn't work start crying
If you use Proxi sensors you have to insert 2 diodesi nto the 1a/1b terminals see my seperate thread NPN sensors
Amen
