Massoth automatic control it works
Philbahn
Followig my attempt with npn sensors and a lot of messing around I now have two locos shuttling around the track. May need to move one switch or alter a stopping cv.
So the yellow buttons are now working with regularity
The train enters the station , hit the limit the loco stops and the changes the point, sends the other loco the opposite way, then changes over again:thumbup::thumbup::thumbup::nerd::nerd::nerd::bigsmile::bigsmile::bigsmile:
Re:Massoth automatic control
well done phil... :bigsmile::bigsmile::thumbup::thumbup::thumbup:
Takes some getting your head round but it works. No magnets to buy no expensive track switches. no more watching the same train go the same wayall day. So my neck rotates once then it unscrews
Hi Phil
Are you using the feedback module? what are the NPN sensors?
Paul
Hi Paul , NPN senors are a solid state proximity swich. I use 8mm sensing distance . They run on 5-36 volts
( I have used an old phone charger) they "sink" to neutral and form a volt free contact and put them into the massoth feed back unit along with diodes. Bored yet ?:nerd::bigsmile: See my other post NPN sensors
But they can't pass each other on single track. :rolleyes::rolleyes:
The Force is strong with this one.... :admire:
Sounds interesting Phil
I only use it when I am doing other things and don't intend using it all the time. Althoughb it is a good party trick and it a pity to have it and not use it
Stainzmeister said:
Put another passing loop in, or make existing ones longer/trains shorter.......:bigsmile:
Are we still talking about the train set :bigsmile:
I'll leave that to your imagination Steve
Just got in from work. Got 2 locos out ,changed the numbers on the program and away they went.
Very relaxing and not at all dizzy
Tried it tonight Paul was just going to press the button and the navigator nearly fell in the washing up bowl. Anyway the trains ran all the time
Stainzmeister said:
:rolf: You can always press a button or two and operate another train(s) Phil :bigsmile:
i think you will have to come here on the next open day phil as i think you will be able to advise on my future plans (bows down in deference to superior). :bigsmile::bigsmile:
As long as it isn't this weekend only I am otherwise engaged
It's like computer control, you don't want to use it all the time but it's good to just see that you can
Exactly Paul
wont be till august phill
Been somewhat delayed due to work so I videoed it to night
Sequence of events
First train enters te station hits the sensor and stops. The other train starts in the opposite direction,completes the circuit and re enters the stationand the sequence starts again
To get to the stage takes a bit on doing.
Will try and video it tomorrow or Friday
Cliff George said:
Got any video of this working Phil?
