I have used Elder Tree Cuttings and also Conifer. Both may work out heavier than Plastic but look oh so much more realistic. Look for some one locally doing some Hedge or Tree Trimming and ask for some of the cuttings that appear to be the right size if you do not have any suitable Trees yourself. And yes those in the Pic are certainly the real thing.YES Sir, that is what I was looking for. Are the ones in the pic plastic?
Where did you get them
Regards The Eagles Nest
what do u mean?
I understand that G scale is the closest scale to my 1/24 scale.
I am just starting to build trucks. and what I need to do is fill my logging trailer with logs.
Where might I find logs that would look very realistic model
Regards from The Eagles Nest
Cordyline is freely available in the South West - often known s Torbay Palms.I use the trunk of a plant called Cordyline for my logs.
They are a fast growing tall plant with a log like trunk, if you cut them and leave them to dry for a few months you end up with a log that has good bark texture but weights less than balsa wood for a similar size piece.
The good thing about them is that the top that is cut off readily strikes and anew plant is available for more log harvesting down the track.
variety is sometimes sold as""Chinese Happy Plant as well.
Dunk 'em in a timber preservative - last for everSoft woods, where used as scenic lineside items do attract insects, so harder woods are preferably and last longer. Annual pruning (if you have trees) can supply replacements if needed. A friendly neighbour might provide some if you have no trees.
Small chopped logs were a feature on those lines in the USA that used wood burning locos, such as those in Colorado and New Mexico. Small lineside stacks can be seen in old photographs.
The Bachman tender, which has 'plastic' logs really spoils the model. I replaced mine with 'small logs' made out of cherry wood; an immediate improvement to the models appearance.
