Fred2179G
( Henri asked for the whole story, so here it is.)
I guess I'm working through my stack of kits. This is a sort of photo essay as I had plenty of time for taking 'under-construction' pics. It was started around the end of March - the earliest photo is time-stamped 03/30. This post is now complete, but there will be another conclusion when I add the wheels.
The little caboose above was purchased to be the end of my little train when I put batteries in my little LGB Feldbahn loco. As it happened, I came across a small LGB van which suited it just fine, so the bobber caboose was put on the shelf.
It's a 'craftsman kit', of basically a bunch of laser cut wood and metal parts that you glue and paint. The only photo I found when I was looking for a small caboose was this:
and this photo is the only one in the instructions, reproduced even smaller. However, a couple of days ago I did another Google search as I was mentally planning this article, to see if there were any better photos, and this link popped up:
Ozark Miniatures bobber caboose kit | Garden Railways Magazine
. .a product review from GR Magazine in 2011. It included some decent photos and descriptions of (most of) the problems I had already found!
In my limited experience it is better to do as much painting as you can before assembly. The paint can be touched up if necessary, and it gives you the option of multiple colors. Here's most of the metal bits being painted with flat black primer. I then sprayed another coat of satin black on the railings and grab bars.
The blue painters tape is taped sticky-side up on a flat surface and the metal bits pressed on to it. Little things like door knobs don't get lost, if you are lucky. Of course, you have to spend a while cleaning all the flash off the bits, sanding the surfaces smooth, and then washing them thoroughly in soapy water with a following rinse to get the grease off. You can also see the frame taking shape, and it needed a coat of black primer. I did the end beams separately - not sure why I decided that, but it turned out to be a good decision.
They gave me 2 pieces of scribed wood to make the main roof, and 3 pieces to make the cupola roof. I soaked them all in water and then roped them to a paint can with a couple of pieces of wood to press the edges down. After a couple of days they were dry and curvaceous.
The bodywork got a coat of dark brown primer, then a lighter, more red shade that I found on the shelf. When they were dry I got out my Woodland Scenics dry transfer lettering and found something to label it with. Nothing fancy!
