FrenchChuffed
thanks i will recearch local B&Q
always do also, its a great line and always good photo'sPaul, i so enjoy your photos.
Boahh, looks great!
Where did you got the Mh6? Is this a live steam?
Best Regards
Lovely atmospheric image.The Mh6 used to be live steam, but I could not get it to light successfully, so I used an LGB Rugenslok chassis and made it a digital sound loco which ran pre3cisely as I wanted it to.
I sold the inner boiler and original chassis to a nice man from the Netherlands, which paid for the Rugenslok donor chassis.
Though you had been quiet for a while just the other day, clearly you have been busy.I have been "terra-forming"
More track in the same space......
The plant pots will go when I get round to planting the conifers.
Quite a bit more detail to be added yet.
Is the piece of blue wire on 56 to enable double heading? If so may I suggest you use a black equivalent, make it less obtrusive in your superb pictures.Another shot of the depot. Now the coal Staith phone box and coal dust have been added. The snow plough attachment is on the rhs of the double shed. Just the water crane to go now. The crane needs to be robust unlike the Pola one I had on the original layout.
The blue wire is to enable cab first running as it is not possible to fit a hook to the front of U Class loks as you know. The blue wire ensures that no unintended decoupling takes place when passing over changes of gradient curves.Is the piece of blue wire on 56 to enable double heading? If so may I suggest you use a black equivalent, make it less obtrusive in your superb pictures.
Aha get that. I use double hooks on all stock with none on locomotives. Decoupling on my line has been near eradicated by lowering the locomotive coupling both ends by 20-30 thou. A piece of plasticard cut to fit the coupling slot with a hole works just fine.The blue wire is to enable cab first running as it is not possible to fit a hook to the front of U Class loks as you know. The blue wire ensures that no unintended decoupling takes place when passing over changes of gradient curves.
Thank you Jon. I do endeavour to add a little realism to the shots. View attachment 296322
