Lights on a class 66
ASG
Trains, Old Motorbikes, Beekeeping
2 Jan 2010
57
Cheshire
I have recently purchased a Aristocraft class 66 loco and have noticed that you cannot have both headlights on at the same time it's either one side or the other. There is a switch for lights which put the main light on at the front(top) of the loco, both side lights and one headlight. It also has a switch for day or night lights and this just toggles with side the headlight is on, left or right. Is this normal as I'm not to familiar with modern loco's.
I'm probably going to change the wiring sothe night setting has all the lights on at the front and the day setting just the side lights.
Regards Andrew
spike
It's me
Upper Drakes Bottom
www.weathersatellite.info
Regards Andrew
Think thats the normal lighting for Class 66 :thinking:
ASG
2 Jan 2010
57
Cheshire
Thought it was normal, didn't think it was a fault with the loco, just seems a bit weird, wondered if anybody knew why? :thinking:
Rob
3 Nov 2009
478
71
Liverpool
www.flickr.com
its normal and completely prototypical.
The light should be on the off-side (right hand side) during the day and the Drivers side during the night, the two are never on together.
just makes sure the headlamp is on the most beneficial side and reduces dazzling of passing drivers at night.
Tony
Model railways
28 Feb 2010
4,593
1
East coast Essex
www.facebook.com
Any excuss to publish a photo or two and got her fresh from her box tonight so had to test the smoke gen as well LOL
Tony
chris m01
424
Birmingham, UK
I'm sure Dave Hub will be able to explain everything about the lights - he drives real ones.
Dave Hub
everyting
1,534
9
west mids
Cheers for the opening Chris.
Chris is right I do drive these in real life.
There are settings in the loco;
marker lights: primarily used for yard work.
the day or night headlight: which will be lit in conjuntion with marker lights.
Tail lights:red lights for displaying in light engine running on the rear.
Only time you will ever see both headlights lit at the same time is if they have been set to hazard light mode, then both headlights flash at the same time. In an emergency Hazard lights would be set to flash and red tail lights also displayed, which remain steady. (hope you never see this in real life)
If you are really keen the current rulebook module relating to train running is in the public domain and accessable to all if you know where to look.
Here is a link to railway group standards online, relating to this module
the module you will want is TW (for train working) and the section is section 4 "external train lights"
http://www.rgsonline.co.uk/Rule_Book/Rule Book Modules/TW - Train Working/GERT8000-TW1 Iss 8.pdf
There are many other modules some which may interest you such as those that deal with faults of the light, giving you permission to use the day beam at night etc. others telling you when to put on your hazard lights.
It took about seven weeks to cover the whole rulebook in a classroom so you might just want take my word for it, unless this really interests you.
hope this helps.
ASG
2 Jan 2010
57
Cheshire
Many thanks for the reply Dave
I will certainly have a look at the link, but probably won't read it all if it's as long as you say.
Andrew
hagen
Kongsberg, Norway
