I have to confess to a varied career. I was educated and worked as a professional electrical engineer then I became involved in the legal aspect of contracts. I next made the mistake of applying for a management position which I got and regretted.
So when I read a document I expect it to be technically accurate, unambiguously written and understandable by others less technically trained (or it should be made clear that it is a technical document).
I am often disappointed when it comes to DCC!
As I understand it LGB MZS in s mode sends a single pulse when the F1 key is depressed. If the command station is set to s mode it then waits for a interval for another pulse, and so on until the interval timer times out. It then translates the sequence as a 'word''
Hence, for example, if you press the F1 key 5 times quickly the central station understands that as an F5 command in s mode.
LGB describe this as 'serial' operation as I understand it.
However when set in p mode the F1 key pressed five times will cause the F1 output to switch on, then off, until finally on when the key is no longer activated. But pressing the F5 key once will sent the F5 command to the central station.
I don't have an LGB MZS system so I cannot prove this.
According the the LGB user instructions, setting CV51 bits 1-8 allows 'Only parallel commands (NMRA) via function buttons 1-8' I have done a search on NMRA RP 9.2.2. but cannot find a reference to parallel. CV51 is 'manufacturer reserved'. It is also beyond my technical experience that a parallel connection involves only two conductors. (Two rails to relate the the physical).
I think LGB have done a fantastic job in developing the garden railway hobby. I have many 'red boxes' but I have a fair number of other colors too! However I think they have got it technically incorrect when assigning descriptions to s and p modes.
I believe they are correctly S(ingle) and P(acket) modes and I can well understand why LGB did not want to let technical 'gobbledygook' prevent brining MZS to the marketplace. Even in 2011 I see references to 'the Dark Side'. Your grandchildren would be disgusted at your technical reluctance!
In summary
s = single
p = packet
Have I missed something?
(still counting rivets - and micro processors!)
In case you are wondering, I have been looking at other DCC manufacturers, particularly Lenz and Zimo, so I'm expecting more than what has been on offer for a very long time (in terms of electronic developments)
In summary
s = single
p = packet
