Hi, I need some help with my electric points. After some testing I found bit of a problem with the blades wondering and causing derailmants. The manually operated points don't suffer with this as there is the springs to keep the blades one way or the other, but there is nothing to keep the points 'locked' on my electric ones. Sometimes after only 3 or 4 passes the points begin to shift, letting the wheels drop on either side. Is there something missing from my points or is this a common problem?
Many thanks, Tim
Many thanks, Tim
