Madman - 16/11/2009 3:33 AM
<strong><font size="3" face="comic sans ms,sand">If I wanted to do a small and simple indoor shelf type layout, which LGB MTS system should I look for?</font></strong>
To build a little on Mike's answer...
The original MTS1 system will do absolutely fine for an ultra simple layout. You will be limited to 8 locos (Either all 8 digital, or 7 digital, plus 1 analogue) on the layout simultaneously, though that may not be an issue. MTS2/3 permit up to 23 (of which 1 analogue).
You will be able to use LGB wireless controls and all the other MTS equipment (point modules/ reversing loops etc) with an MTS1 central station. I did so for the past 10 years, only upgrading to MTS3 (bypassing MTS2) this year.
There are two downsides to getting an MTS1 system. First, if someone brings a loco to you with a DCC address higher than 8, it will need to be re-addressed before it can run on your layout. That was the main reason I upgraded to MTS3 in the end: MTS1 was still working fine for me on my own! Second, the hand controller (mouse) which comes with the MTS1 set can only be used with MTS1&2. It can't be attached to the MTS3 central station.
However, if you get as far as wanting MTS3, you'll probably have got the bug big time and want to evaluate more widely what's available at that time. Bearing in mind that technology develops pretty steadily, going in with an MTS1 as a bargain basement item may not be a bad idea.
Please feel free to PM me if you want to discuss offline, or bounce your ideas around here if you want, for the benefit of other DCC/MTS newbies.
