stevedenver said:
keith what were the symptoms /problems?
as the loco has a worm to gear drive on one of the axles-and then power transfer via the belt to the other axel-i wonder what the burring was
as the belt has teeth , i would think grease doesnt hurt
in fact i actually put a touch on mine (Olomano) to quiet things down
as mentioned the belts are essential and rare
-i wouldnt dare touch it with any chemical other than mild dish soap to clean-
while these locos were shown in the catalog often pulling 4-5 cars
i have repeatedly been told by the former LGBOA techs that these little engines shouldnt be taxed load wise
they think 2 cars is the max
for me, its 3-4 so longas on level only, otherwise 2
-and i now follow this religiously
Steve
I have only just seen your post , sorry.
I got the impression that the burring was the belt jumping on the drive gear on the wheel.
Since removing what was undoubtedly grease from the axle bearings which had got onto the belt and the gear using only my finger(!) the loco has been running happily with 3 Summertime coaches on level track around Aristo 20" diam' curves for several hours at a time for the last 3 days.
I will investigate the suggested sources for a replacement belt but for the moment at least I will leave well alone.
What I did find was that the Summertime coaches, the ones with the reversible seat backs would not negotiate the curves due to a combination of the body mounted coupling on the back of these locos and the projecting roof ends clashing. This stalled the loco and presumably caused the belt to slip. I had to substitute the more utilitarian 3041 coaches, those with the fore and aft seating and use a paper clip coupling in order to run the loco front first.
Still, the 2 and 3 year olds are happy with it which is all that matters.
