I have an older Feldbahn cabbed loco here..
It came to me with a burnt-out decoder. Found the motor was 'stiff', and took lots of current on analogue. - Decoder removed as it was ash!
Fitted a new motor, new Emotion-M decoder, and sent it back.
It has come back to me as it runs hot.
If I run it on analogue, at ten volts it draws 0.2Amps. So 2W and it gets warm to the touch. - Run for an hour.
If I run it on DCC, it still runs, but the motor gets too hot to touch for any length of time after about 30 minutes.
Both the above tests done with the new motor, AND new decoder, so DC is going through the decoder to the motor when running on my analogue supply.
The only (obvious) thing to check is motor frequency, the CV for which is CV 9, and this is set to '0', which should be 16KHz and the default (manual suggests best) value.
Does anyone have any ideas on this please?
