tac foley
NOT, I hasten to add, on MY part, but LGB's!!! I know, I know, it's hard when you find out that the company you've been worshipping for decades has actually screwed up, but it seems that in THIS case, they have...
Y'see, I have a collection of cabeeses going back many years - this is one of them [awaiting a re-paint into something a little less like a lil' red caboose] - the LGB number is 42793, and this pdf purports to be the instructions for it - https://static.maerklin.de/damcontent/c7/d6/c7d6c5561203e89e32d228710b6f2e511559901761.pdf
I want to take it to pieces so that the repaint can be done properly, in accordance with my standards. Please note the configuration of the cupola - there is no test, but it is rather important.
I also have THIS older caboose, LGB number 4071 -
Note, please, the configuration of the cupola on THIS model.
I think that most here would agree that they are not the same, and that dismantling it using the instructions for dismantling the other may well be different.
Referring to the PDF, you can instantly see that this is, indeed, the case. and why would I refer to the pdf? Well, it is because pages 1 through 13 refer to the top model, but page 14 refers to the lower model.
I wrote Maerklin/LGB or vise-versa, pointing this out, and was advised as follows -
Dear Mr. Foley,
the only user manual we have available for 42793 you will find on our website under
Sincerely yours,
Your Maerklin Customer Service
Frank Mayer
Gebr. Maerklin & Cie. GmbH
In mitigation, this pathetic 'instruction sheet' is all that accompanied the top caboose - a pretty useless 'set of instructions' for dismantling a fairly complex model with lighting and numerous internal parts.
It seems that to company is unable to provide either an explanation, or a correction for what is plainly a co- mix-up.
So, anybody here taking one of the newer cabeeses to peeses?
TIA
Dear Mr. Foley,
Sincerely yours,
Frank Mayer
TIA
