I have been asked to sort out a limited edition LGB-Aster Garratt..
Looks like it has been stored in a garage/shed for some of its 20+ years and the damp has slightly got to it.
The running-board / chassis and many of the parts at that level are steel, and a certain amount of rusting has broken through the (satin black?) paintwork. So far, all I have done is clean-down the loco, and look into freeing the motion. - Two of the pony-trucks were either very tight, or totally seized.
I think it is better to keep things 'as original', but would welcome others thoughts on this? - I could rub-down the rusted areas. Touch in with primer/surface, and then repaint. Think this could be a nightmare to only get paint where it should be!
The other area of concern is the cast 'brass?' fittings and copper boiler-bands..
The castings have been left with a slightly rough finish (not highly polished) and I am not convinced they are really 'brass'. - They have 'mellowed' and now appear almost as if a dodgy gold-colour. My thoughts are I will not to able to get in all the nooks and crannies to polish these up, even if it was a good idea in the first place!
So far, I have started sorting the running gear. Only appears the two pony trucks are a problem. Getting into the motor-blocks would appear to be a nightmare, as I would have to remove all the added detail to get into them.
No skates, so wheel-backs cleaned up. Tyres and flanges polished-up to aid pickup as well. Seems to run nicely, even at a crawl (on rollers).
Body / Paintwork:
I have been cleaning this with a 50:50 mixture of distilled white vinegar, water, and a couple of drops of washing-up liquid as a wetting agent. This applied with cotton-buds. - Slow, but sure..
Things like the cab roof (presumably brass) are showing signs of 'starring' where moisture has got under the paintwork causing raised 'blisters'. Again, it is whether to just clean things up, or to strip and repaint. Cab roof is removable, so could be dealt with properly and re-sprayed, but other areas would not be as easy to deal with.
I would welcome other Forumites thoughts on how to proceed with this.
I think it might be better to 'conserve' what is there, and then let the new owner decide how far things should be taken in re-painting etc.
Thanks all,
Phil Partridge.
Body / Paintwork:
Thanks all,
Phil Partridge.
