LGB 65002 sound unit
madman1981
hi guys,
i got a new loco a few days ago which came with a LGB 65002 sound unit fitted with as standard i understand a MTS decoder inside. I have tried programming the decoder a number of times with no luck using my massoth system (just keep getting crosses even thou the sound unit is beeping). Does anyone have any experience of these as im about ready to throw it in the bin lol. it has a date of 2002 on it which im guessing would place it in the serial camp? or did not all of these have MTS?
any help would be appreciated as i have no sound lol
cheers
Richard
Ps i only get start up and idle sounds
Have you tried it after programming? I've got one and it had to be programmed at the same time as the loco decoder or I just kept getting error messages. I powered it up off the auxiliary power socket as it needed track power all the time.
Like another thread is the sound turned on if you get nothing?
Have you changed the loco address? Sometimes this does not change the sound unit at the same time. Try going back to the original address and see if that helps.
Richard,
when programming, have you isolated the motor decoder from the LGB sound decoder? You cannot simply programme when two decoders are present. This may be confusing your DCC system.
You need to remove the LGB sound unit and separately programme. I regularly programme these units, but only using the LGB programmer and MTS 6.0 software. There is not much to alter when using DCC.
Ive tried programming the unit together and seperate but with no joy. I have also programmed the CV value 1 for the decoder address directly in case the massoth loco address function didnt work correctly but this didnt seem to work. When i was programming the sound unit directly one thing i did do was plug the sound units wires directly into the back on the central station unit. If i remember correctly ive had trouble with this before when programming loco decoders with me only being able to program from the track unless you use the programming cable. Bit of a long shot but will give it ago.
It wouldn't be anything to do with the fact the decoder in the unit might be serial and not paraell?
I've never had to do that and I've used a SPROG and the LGB programmer, in fact with the LGB unit it wouldn't recognise it unless there was a motor and decoder present &:
Madman said:
It wouldn't be anything to do with the fact the decoder in the unit might be serial and not parallel?
Unless the Massoth unit works differently I can't see why as I've programmed successfully using a friends parallel MTS unit and my sound unit was bought before they went parallel as my MTS2 unit is serial too.
Paul,
the LGB sound decoder needs a load, a speaker, to be able to be programmed. How you could programme both a motor decoder and the sound decoder, simultaneously with a LGB programmer or the Sprog, has me confused as both decoders share similar CV's and would read as separate ID versions. I do not use the Massoth system and rely on the LGB programmer and have done many LGB 6500X series sound units.
You should be able to program both together (especially the address) as both decoders should recognise the programming commands and act upon them. However, the programming unit must supply enough power and will probably not recognise the conflicting programming ack's from each decoder and report a failure.
Load on a decoder is normally used to assist in generating the programming ack and the majority of decoders should accept and act upon the programming commands without a load, obviously there will be no feedback ack generated for the "programmer" to recognise and it will deem the operation a failure.
Tim
I agree but I found programming the loco independently was fine but I kept getting error messages for the 65xx on it's own so I programmed the loco and then added the sound unit to program the address, I wasn't trying to read the unit as it didn't seem to recognise it with just the speaker.
Peculiarities of the system? :bigsmile:
I changed the loco address of my V52 using an MTS 2 with Universal Remote, but it didn't change the address for its LGB sound unit.
BigJack sorted it for me on his Massoth 1200Z.
As PaulRHB mentioned, perhaps a perculiarity of the system....
Hi guys,
i finally got this working last night :) only problem with it now is its only 14 speed steps or should i say 13 as when i get the 14th the engine sound goes back to idle lol
oh well cant win them all
cheers again guys
Apologies for resurrecting a fourteen-year-old thread, but is there any updated consensus of opinion about whether it is best to program both the loco decoder AND an LGB "black box" sound unit together or separately, regarding the loco number (CV1)?
I've had an old, hitherto unidentified sound board kicking around for years - stripped out of an old LGB 2095 "Whizzy Cranks" when I Battery-DCC-ified it using an XLS. I never knew what the origins of the old board were until yesterday when I peeled off some old double-sided tape and realised there was a label underneath it reading 65002! It appears to be the "guts" of an old LGB Euro Diesel sound unit, including board, speaker and volume pot, but taken out of its black box plastic housing, and then protected with some clear blue heatshrink over the entire board. I assume it is DCC-capable (it was in a DC loco when bought), so as I've got it, I'll probably end up re-using it in something at some point - searching for info on it brought up this old thread!
LGB advice in the day was to do them separately as if you wanted to change ny of the sound profiles or other things once linked was not possible.
You really need to be able to isolate decoder / sound-unit, as you will need to program each individually.
Thanks all - if/when I ever get around to putting it in something, I'll just set the desired loco number on the driving decoder and the sound board separately before putting it all together!
