LGB 55045 and LGB 55025
Darren Lalonde
I am trying to program my switch decoder with the lgb software and 55045 interface.
When i plug in (green/yellow) to transformer and brown/white to decoder (in) and have bridged the prog terminals i get a read light. The software recognises the device, but will not program it. I keep getting "Maximum Input Current Exceeded" and will not read eprom values.
Any one got any ideas what i am doing wrong?
From memory I think you need to attach at least one point motor to give it some "load".
Yep.
Many thanks for all your replies.
I have tried every wiring combination possible now. With and without motors, train on a track, etc, but still same message. If i unplug the green/yellow wires. The pc thinks it is doing something and spins round the 4 addresses, but doesnt actually write anything. I presume i should be able to read? If then try again it cant contact the 55045. I must have managed this somehow in the summer as i have two boxes, both on different address ranges. I just wanted to turn one into an on off rather than a point motor. Any further thoughts! Another hour wasted :-(
Hook the two together without going anywhere near a computer. Towards the rear of the manual you should find CVs for the various flashing and steady light modes. As the Meercat says "Simples"
Lets start from the beginning.
Have you read the instruction file loaded to your PC when you installed the software.
MTSPC.PDF.
Are you connecting the 55045 directly to the 55060, computer and points module with no other bits, track, locos, splitter units etc.
Is a switch motor connected to terminals A
Do you need to unlock the switch decoder by changing a CV value - check your instructions.
Is your 55060 compatible with your version of windows - check the instructions.
What COM port are you using. Serial or USB?
Sorry, my fault. I played around with my switch decoder 55025 with a universal remote controller 55015 using the supplied insert module for programming cvs into whatever and by changing the CVs in the 55025 to the assigned channel 1-4, 5-8, 9-12 or whatever. I don't use a computer and had no problem producing steady current for lighting or flashing lights.
This may not help you Darren as I don't have an LGB central station, but with a Lenz this is what I did. Connect up the 55025 as shown below:
Point motor (PIKO in this case) via orange and white terminals marked A, and command station via red and blue. Make a short circuit across the two terminals marked Prog (black wire above).
Now in my case I connected the red and blue terminals to the programming output on my Lenz CS. Then I can read and write CV1 which is the value used to set the address block. I changed it from CV1=1 (address1-4) to CV1=17 (address 17-20).
Now you can disconnect the black wire and connect the red and blue to DCC power instead of programming, and fire the point motor using the new address, 17 in my case.
If you try this without the point motor then you get a "decoder not found" message or whatever the equivalent is.
I am guessing with the LGB CS you can switch from "normal track power" mode to "programming" mode using the same connection, but as I don't have one I can't confirm.
I don't know what the basic controller is but if you have a 55015 controller there is a YouTube video here:
Thanks all. I've just tried reading the valued from a loco and the pc isn't seeing reading these either. I thought it was me doing something stupid. I've had my LGB stuff a long time but with kids and everything have only started to permanently install it in the garden and managed to program the decoders in the summer with the same laptop windows 2000, standard com port (no usb) and the standard lgb software. I do this so infrequently i thought it was me. The only conclusion i can come to now is that my 55045 doesnt work any more. the lights are on but no-one's home. The same pc and software drive the 55060 fine and works the points, etc. I just dont seem to be able to program any more.
Well, if its all working as far as running trains is concerned, I suggest you find a local DCC'er to just set the address for you.
