LGB 25910 KJF narrow gauge loco, drive problem
Jonben
23 Mar 2017
11
South Notts
Anyone know which screws to remove to get to the motor/drive.
Problem is the power pick up/ wheels have power but drive is intermittent.
Neil Robinson
579
N W Leicestershire
This diagram may hep a little.
http://www.maerklin.de/service/produktservice/listengenerator.php?brand=7&artikelnummer=25910
Remove the screws numbered 7 and 18 that go through the baseplate (not all are shown in the picture) and then remove the baseplate.
I fixed a similar problem with a steam outline version. The motor tabs needed tweaking slightly to make good contact with their supply wires.
4,996
There has just recently been a pretty big thread on a similar line.
3,522
Clean the 'tyres' and back of the wheels where the carbon brushes rub..
3,522
It looks very much like the gear, driven from the worm, is worn??
It should NOT be concave.
Zerogee
Clencher's Bogleman
1,723
North Essex
Ooh, yes, that gear does look a little bit worse for wear.... has the loco had a lot of running? The gear should last a lot better than that!
Motor worm gear perhaps meshing too tightly, and chewing into the plastic gear wheel...?
Jonben
23 Mar 2017
11
South Notts
When I tested motor disengaged from gears powered via the pickups it was very reluctant to spin.
Any idea what the circuit board does?
