I have just fitted two new 55021 decoders to this model. One for the engine and the other in the tender. Both motherboards have had their dip switches set to OFF.
I have given both components a CV1 address of 8 (loco number) as per recommendation from LGB. i.e. same CV1 number applied to both units.
I have also connected the grey interface cable between the two components.
So therefore when I test, the tender seems to drag when going forward and pull when going backwards with the tender light being very dim. When going forward the engine light is bright as I would expect.
So, any ideas as to what is happening here? Perhaps I should test the tender on it's own as I know the loco works fine on it's own.
Help, what's happening?
