LGB 20275
Blang6875
2 Aug 2022
5
Switzerland
How do you extend the duration of the power pack on the LGB Ballenberg HB33 form 2022? I have tried changing the CV's but no luc>
8 Mar 2014
7,806
972
San Diego
Armenia
www.elmassian.com
Umm.... hard to understand...
So, you must have a DCC version, since you referenced CVs
Do you mean a "keep alive"? Where the loco can run for a while with only onboard stored power? Like a capacitor bank?
"power pack" normally refers to the power generating source for a layout, that is not on/in the loco.
Is this for movement or sound?
Blang6875
2 Aug 2022
5
Switzerland
Primarily the sound but both would be ideal. I have a lens lzv100 set up for programming.
8 Mar 2014
7,806
972
San Diego
Armenia
www.elmassian.com
So the problem is an interruption in power that causes the sound to quit or "reset"?
So the thing you will want to do is to add a "keep alive" to your decoder.
It is an energy storage unit that will keep the decoder from resetting....
First off, just to be sure, what happens? Are you running slowly and there is a dead spot and the sound changes?
Blang6875
2 Aug 2022
5
Switzerland
I am running slowly and the engine hesitates and the sound drops while running over a Piko switch. LGB says that the decoder has a keep alive and shows cv’s to change it but I am missing something as I have changed them and there’s no difference.
8 Mar 2014
7,806
972
San Diego
Armenia
www.elmassian.com
Ahh, the keepalive might not do what you want, it might avoid resetting the main decoder, but it might not support the sound output.
What is the decoder model? Perhaps we can find some more information on it.
I would be surprised if the keepalive was not "on" by default... maybe that is why no difference, it is already on...
Blang6875
2 Aug 2022
5
Switzerland
Well as is typical of Märklin there is no model number for the decoder, they say it is a 32 function 27 pin decoder an you need to set cv’s 31 and 32 to different values for cv’s 257 to 512 with 260 to 290 being specific to the buffer.
8 Mar 2014
7,806
972
San Diego
Armenia
www.elmassian.com
So, this is a recent decoder, since the Marklin takeover.... so it must be MFX capable...
I searched a bit, hard to find the manual, do you have a link for the manual?
Also seems it was produced, then not produced, then produced again... I expect yours is the newest production with the mfx decoder...
wandgrudd
57
Greg, I think part of the problem is LGB say it has a keep alive, when in fact I don't believe any of them actually do, I am sure it's a translation error, the instructions for all the new MFX chips, mention the same thing I.e. a "keep alive" (in the English translation) I have tested multiple different locos including the one above and if a keep live is factory fitted it does absolutely nothing, till you buy and fit the "55429" power storage device. What I believe the instructions should say is that it has the facility to accept a keep alive (i.e. there's a little plug on top of the MFX chip now) and you can alter the CVs to suit, not that it actually comes with one.
8 Mar 2014
7,806
972
San Diego
Armenia
www.elmassian.com
I suspect you are right.... if there is a capacitor bank on the decoder, and it is set up for G scale, the capacitor sizes will be significant. It would easily be determined by a phots.
If there is a open socket that is the keepalive socket that would be the clincher...
meiningen8
20
There has been a thread on this forum with regard to the 55429 power buffer and how and where to fit one
8 Mar 2014
7,806
972
San Diego
Armenia
www.elmassian.com
this thread?
Blang6875
2 Aug 2022
5
Switzerland
Here is the manual that came with the decoder, it surely seems to indicate what it calls buffering!
Cheers
Bill
  • LGB decoder.pdf
Diesel2000
18 Feb 2020
207
22
Chicago
Cheers
Bill
LGB does not include keep alive devices in their locos - they need to be added. The MSD3 decoder DOES have CVs used to control what aspects to apply power to (motor, sounds, lights, smoke, etc) as defined in the manual.
You will need to install this to the decoder to provide keep alive power - 55429
Diesel2000
18 Feb 2020
207
22
Chicago
This is 100% correct
