Martino
I've found in a pile of track I recently acquired an LGB 1225 double slip.  It seems in reasonable condition.
It has strange motor on the side, but of course no instructions.
The research I've done on line indicates that the slip is only meant for indoor use. I assume this means the motor isn't weather proof.
I run a DCC set up. Does anyone know if this could be operated with DCC by changing the motor(s)? I use Train Line switch motors everywhere else.
I don't really have a need for a double slip, although I do need a simple crossing of the same angle as the slip, so could just use it with the blades locked. I guess it would be 'nice' to have the ability to slip, but aren't the curves on this R1s?
Any thoughts, comments or suggestions?
