tramcar trev
As those of you following my progress will recall I made up some bi colour led signals. Sooooooooo being one to want things to work I tested the leds at every stage of manufacture and once satified I encapsulated a batch of both types... they all worked after being demolded.... NOW its getting closer to actually having to use them and I tested them again. Quite a few don't work either or colours or nothing..... So the only possible expalation I'm thinking that as the resin "matures and cures" fully it shrinks by only one modicum and thats enough to tear the soldered joints inside.
I had to prove my theory so using a 1mm ball in my dental drill I excavated the back of a couple to expose the soldered joints and found that precisley is what happened a touch with the soldering iron with a fine tip and all is A ok... Then nurse filled the holes with plasti bond....
Certainly a problem I did not envisage.... I may have to rethink this... Curiously its only the signals themselves, the other encapsulated components are not affected.... probably something to do with the fact that the polyester resin I used does not actually stick to the LED casings
