ge_rik
You may recall a thread a couple of weeks ago about using a cheap LED dimmer as a remote control for battery locos.
http://www.gscalecentral.net/m171394
I invested in one for my railbus (still under construction)
I removed the circuit board from its housing and wired it in.
It works well (considering the price) - but I've hit a snag and wondered if any of you electronics whizzes had any suggestions. I thought I'd wire the LEDs I'm using for the headlights into the motor circuit so that the headlights would come on in the direction of travel. Simple, I thought. Wire them across the motor in opposite directions so only one set will glow dependent on the way the reverse switch is set.
(NB resistors in series with LEDs not shown)
Trouble is, when I power up, the LEDs glow dimly at first then get dimmer as the speed increases before going out completely when the dimmer unit produces full power. I assume it's something to do with the internal resistance of the motor. I'm using 12v of battery power as the dimmer unit works best on this and the resistors for the LEDs are those rated for 12v for the LEDs I'm using. When I connect the LEDs / resistors directly to the batteries they shine beautifully.
As I mentioned in the earlier discussion - I have a basic understanding of electrical circuitry and an inkling of practical electronics but stumble at the first hurdle when it comes to theory.
Any suggestions (polite and/or anatomically achievable?)
Rik
Rik
