Laying tracks in decking
Right, this is it! At last I'm starting work in the garden and I've been granted permission to build a new line. As my garden is small I intend to lay some of the tracks through a deck that I'm building. The proviso is that the rail tops are flush with the top of the deck. I've seen some pictures, but not in great detail. Has anyone else done it, and has anyone got any suggestions please? The track I'll be using will be LGB for toughness,
Thanks in advance
Paul
Are you hoping to have curves in the deck?
Yes, I'll have to I'm afraid. I'm hoping to get away with a removable section on the other side of the deck, but one side will definitely need a 1/4 of a circle
Make a Template of the track base then use a router to make the trench in the decking the depth of the track. When the track is fitted to the deck you then fit a insert of decking between the rails to protect the track. You can just rebate the rails into the deck but this will be a lot more difficult to do.
That is what I was thinking. Use a template of a swinging arm to maintain a smooth curve. The straights are easy - just space the decking boards to the sleeper width and infill with something shallower.
I did think of a router, but I've never used one before, and I value my fingers!
Yes like all power tools (or even, all tools) you must use them safely and properly. If you have not used one before may be worth asking advice from a friend who does know how to use, but used properly are a very useful and versatile tool. recessing for the track should not be difficult but you do need to use a jig to get a nice clean line. Having said that, it is quite possible to do free hand lettering for example, but decking is not the place to practice really !
Thanks in advance
Paul
I do have a Router and know how to use it. But curves would indeed be tricky with a Guide being required that is well held in place and also altered for the second rail, tricky to get right. Then there will be holding the rails in gauge with a special track gauge. Finally my biggest worry you will have created a couple of Trenches for Water to sit in. Not condusive for long life of the deck bearing in mind that you will have probably cut out most of the Preservative in creating the groves.
Perhaps the best bet might be to Double up on the decking where the Track will go. Then fill the deck with off cuts to the sleeper ends. This though may give issues with Stock Clearance? Track could be lifted to be flush with the top of the deck with perhaps some packing, plastic thin Filcris might do that job.
Don't know if you are using electric for your track you could use aluminium bar set in a groove like a tramline that will give you less cutting out and bend to what ever radius you need.
Shaun
One thing nobody has mentioned is strengthening, if you are to router out (or any other method of reducing the thickness of the decking some type of support will be required as the integral strength of each board will be compromises, and when walked on could collapse.
What Radii of track are you using?
I'm not far away from you in Cambs, so I might be able to help....
That's something else I've got to sort out! Now I have the base laid I'll have a measure up. Letc it be known that my planning is implacable:think:
Another approach would be - lay the decking level as normal, fix your track where you want it with screws then use 10/12mm thick rubber/synthetic rubber tiles to the whole deck (safer walking surface for all the family) but make sure there are small parallel gaps in both the decking planks and the rubber tiles to maintain good drainage and drying out.
Where you have the curved track, you can neatly cut the rubber tiles to suit.
Another benefit of this is that if you move house, there are no puzzling recesses in the deck for the new owners.
Could you just get away with routing grooves in the deck 45mm apart and do away with track altogether and line the grooves with copper metal foil for power conductivity.
I have seen this used by slot car people for their tracks.
Trains on rails and cars with a guiding slot and power pick ups are very similar when you look at it.
One problem would be corrosion of the foil but a conductive grease could be used to keep moisture at bay.
Just an outside the box suggestion.
Similar to my suggestion post 9
Shaun
Thanks for all the help on this. Unfortunately the practicalities of doing and actually using the deck are a bit daunting. I'm probably going to have to revise my :(
Copper foil on wooden slots probably won' work. Slot cars have no weight on the pickups, just a light spring or gravity.
My pal Jack runs track across his deck and uses a wood trim piece along the track to take your weight. You know it is there but the track stays in place.
I've decided that due to the relative small size of the deck, using the track whilst people are on the deck wouldn't be practical. However that may well change if I can get myself proficient with a router!
